Coolant help
Old Jan 22, 2016 | 09:44 AM
Metalslug137's Avatar
Metalslug137 is on a distinguished road
Exclamation Coolant help
Hi all,
I have a 99 Blazer with the 4.3 vortec. Since I bought it (1 year ago), it has leaked coolant intermittently. I have added around 1-1.25 gallons to it this year.
The thermostat has been replaced as it had an overheating issue in the past. I am visually seeing coolant directly in front of engines around belt. The coolant is traveling from there dripping and some rolls to the oil pan and drips.
I will attach pictures later, but is this something I need to be concerned about? There is NO coolant in the oil.
Please advise as it is going to be a daily driver in a week in a half.
Old Jan 22, 2016 | 09:49 AM
okaussie's Avatar
okaussie is on a distinguished road
Could be a bad water pump. Could be weeping coolant from the weep hole in the front of the pump..
Old Jan 22, 2016 | 10:43 AM
CWBDDSPC's Avatar
CWBDDSPC is on a distinguished road
If you want to continue to drive it, yes you should be concerned
Old Jan 22, 2016 | 10:54 AM
It's been leaking for a year, and has not gotten worse.. It only leaks 1/2 the time it sits, it is not an extremely bad leak.. Maybe water pump? It never runs hot the truck
Old Jan 22, 2016 | 12:57 PM
perumotors1369's Avatar
perumotors1369 is on a distinguished road
It may start to leak worse when it becomes a daily driver..Jerry...as written before me, look closely @ the 'weep' hole on the water pump..
AcerDeucerQ
Dec 3, 2012 06:29 AM
Skeeter Cruz
Mar 4, 2010 07:07 PM
felonyblazer96
Dec 28, 2008 10:04 PM
dmheer08
Sep 24, 2008 12:21 PM
Chadoo951
May 8, 2007 05:19 PM
