Coolant issue
Old Jul 19, 2014 | 01:48 PM
98BLT's Avatar
98BLT is on a distinguished road
Default Coolant issue
Hey guys, I recently filled up my coolant reservoir a day or two ago. Then say I don't drive it at all for a day then I go to check the coolant, the reservoir is empty. Strong smell of antifreeze inside the car but no signs of leaks.
Old Jul 19, 2014 | 05:30 PM
joejiz's Avatar
joejiz is on a distinguished road
is rad full? how old is cap? I changed my cap and water stopped overflowing out of the reservoir's over flow tubing on to floor.
Old Jul 20, 2014 | 06:29 PM
98BLT's Avatar
Just by looks everything is stock. No signs of leaks.
Old Jul 20, 2014 | 07:51 PM
jmparker82's Avatar
jmparker82 is on a distinguished road
next step i would do is pull back the carpet on the front on cab floor. Check for wet floor and coolant. I am thinking maybe heater coil is leaking into the cab maybe. Just a guess because i am not sure where the heater coil is in the Blazers. That is where i would be checking next.
Old Jul 25, 2014 | 12:16 PM
LannyL81's Avatar
If there is a strong smell of antifreeze within the cab...then there is a leak; most likely the heater core. May not be dripping onto the carpet yet but suspect antifreeze within the housing.
I think the dash has to come completely out to access the heater core....I know that is what I did when I replaced the one in a '95 I had. Dash does come out pretty easy and quickly though.
Old Jul 25, 2014 | 05:29 PM
jmparker82's Avatar
Keep us up to date on this please. Just in case i run into this issue i want to know what you did.
Old Jul 27, 2014 | 05:02 AM
Pewter2002's Avatar
Pewter2002 is on a distinguished road
Just a moment here. Are you saying you top off the reservoir and the Blazer sits without any use and when you check again the reservoir is empty, or did you drive it at all between checks? This will make a big difference trying to help from a distance. Agree with the heater core leaking if you drove it between checks.
Old Aug 3, 2014 | 07:31 PM
jmparker82's Avatar
Any updates?
Old Aug 4, 2014 | 12:09 PM
joejiz's Avatar
I replaced my rad cap and my truck stopped spitting fluid out of the overflow for months, no antifreeze smell ever in the truck though.
however we are in a heat wave right now and I've noticed a couple times when parking the car that the reservoir is steaming and water in their is boiling, it has spit some out of the reservoir too.
when I fire it up it is 115C and then after running for a bit it goes down to 100C (dead middle of gauge)...
I figure I have crappy water in the reservoir and not full antifreeze with higher boiling point.
Old Aug 4, 2014 | 09:52 PM
jmparker82's Avatar
Yeah. A good flush would be good. Well glad it wasn't something more serious.
AcerDeucerQ
Dec 3, 2012 06:29 AM
Vtec2Slo
Apr 17, 2011 04:09 PM
Skeeter Cruz
Mar 4, 2010 07:07 PM
jdpilot
Jan 1, 2010 11:47 AM
msfan324
May 16, 2009 11:45 AM
