Coolant Leak
Old Dec 5, 2006 | 07:26 PM
chevblazer02's Avatar
chevblazer02 is an unknown quantity at this point
Default Coolant Leak
Well I lost my last post about my 2002 Blazer LS about a coolant odor, well after my 400 + mile trip i noticed an odor of coolant near that back of my truck, assuming its coming from the exhaust... does this narrow anything down to Intake manifold or head gasket? My oil looks fine...and no real lost of coolant, overflow is fine, radiator is fine, heats fine, but i do have that gurgling(sp?) sound behind my dash which everyone said is air..in the cooling system......so if i am really leaking coolant is slow.... Also I know no one can give me an exact price due to labor differances but what in general does it cost to replace a head gasket or an intake manifold gasket?
Old Dec 5, 2006 | 07:40 PM
DetroitMuscle's Avatar
DetroitMuscle is an unknown quantity at this point
Default RE: Coolant Leak
ORIGINAL: chevblazer02
Unless its in the combustion chamber itself it wont come out of the exhaust, being you dont have milky oil, it might be a leak at the heater hose thats dripping onto the exhaust. Does your thermostat housing have an air bleed screw in it?
you can also burp the system by squeezing the upper radiator hose and leaving the cap off, while its running.
Old Dec 5, 2006 | 07:49 PM
Here ya go! Found it:
02 with coolant smell
Please try to keep all of this over there. Thanks!
Old Dec 5, 2006 | 08:59 PM
dcup734's Avatar
dcup734 is an unknown quantity at this point
My 98' Blazer 4wd had a gurgling intermittant noise that turned out to be from the a/c heater core beneath the dash. It was rusty and leaked. You can prove it to yourself if you simply plug/pinch the a/c rubber hose fittings on the engine firewall side which will prevent coolant fluid from traveling through the firewall to the heater core. Turn on the a/c. The gurgling noise should stop. If this proves correct, your heater core is leaking beneath your dash along the lower a/c vents. Check for moisture and coolant smell below the center foot area. Either replace the heater core or disable the heater hoses for now. Good luck!
AcerDeucerQ
Dec 3, 2012 06:29 AM
Skeeter Cruz
Mar 4, 2010 07:07 PM
TAZ454
Jan 28, 2008 10:11 AM
dashyman
Jun 4, 2006 11:21 PM
edacsac
Feb 10, 2006 06:04 PM
