Coolant leak
Old Feb 28, 2015 | 06:31 PM
shawnsha's Avatar
shawnsha is on a distinguished road
Default Coolant leak
Hi guys,,,I'm not a master mechanic but I have basic know how...Just needin some answers b4 I go further.Im leaking coolant from the top left of my engine.Its right beside my thermostat housing where two bolts are..It leaks when the car isn't started I can pour coolant into radiator and watch it come out of a creavice. Could it be a gasket or something?
Old Feb 28, 2015 | 07:31 PM
richphotos's Avatar
A picture would help a lot, what year and model as well.
Could be Intake manifold gasket.
Check your oil and see if it looks like a milk shake
Old Mar 1, 2015 | 06:36 AM
jflora2007's Avatar
jflora2007 is on a distinguished road
Default pump
Could be the same problem I had if it's the same set up. Could be the two bolts are from the left arm of the water pump? I did the same thing and poured fluid in and watched it come out. Not hard to fix except the fan blade has to be taken off. All my big tools were at work so I had a hell of a time. Watch a u-tube on it if you're going to try. I think my pump was pretty cheap and then the fluid. Recommend flushing it out too.
Old Mar 1, 2015 | 09:54 AM
shawnsha's Avatar
I could get a picture later this afternoon but its a 2002 LS with of course 4.3...What could cause the bad gasket...?
Old Mar 1, 2015 | 10:45 AM
richphotos's Avatar
These (2nd gen) are notorious for LIM gasket failsure..
Old Mar 1, 2015 | 11:34 AM
shawnsha's Avatar
Well I have found that the oil is milky looking...so that means it is a definite bad head gasket??could it be done by me...i have tools and basic know how...if not what would the shops charge and how long does it take to someone to do
Old Mar 1, 2015 | 02:24 PM
shawnsha's Avatar
Also if the left side gasket is bad do i replace the other
Old Mar 1, 2015 | 02:46 PM
Milky oil is definitely an indication that you have a gasket leak that is allowing coolant into the engine oil. It does not tell you whether the leak is at the LIM (lower intake manifold) gasket or the head gasket. The LIM gaskets are much more failure prone than head gaskets are. The original LIM gasket set had a plastic frame that would fail rather quickly. Felpro has an updated set that has an aluminum frame that should stand up for a good long while provided things are reinstalled correctly and the gasket surfaces are not too pitted.
Old Mar 2, 2015 | 09:15 AM
shawnsha's Avatar
Thanks everyone one...we gutted everything around the top of the motor.Pulled the intake off and it was that gasket so we didn't have to fool with the heads...Got her running good now.
AcerDeucerQ
Dec 3, 2012 06:29 AM
Skeeter Cruz
Mar 4, 2010 07:07 PM
TAZ454
Jan 28, 2008 10:11 AM
dashyman
Jun 4, 2006 11:21 PM
edacsac
Feb 10, 2006 06:04 PM
