Coolant Leak Behind Front Passenger Tire
Old May 2, 2016 | 01:22 PM
Kevin Heald's Avatar
Kevin Heald is on a distinguished road
Default Coolant Leak Behind Front Passenger Tire
I noticed the smell of coolant inside my truck as well as moisture on the inside bottom edge of the front windshield. While looking for a leak I noticed coolant on the ground behind the front passenger tire dripping off the frame near the inside of the fender well. As suggested in other posts I have checked the carpet on the passenger side floor and it is dry. Would this still be a possible leak in the heater core or something else?
Attached Thumbnails Coolant Leak Behind Front Passenger Tire-img_6346.jpg   Coolant Leak Behind Front Passenger Tire-img_6348.jpg   Coolant Leak Behind Front Passenger Tire-img_6349.jpg
Old May 2, 2016 | 01:44 PM
richphotos's Avatar
Could be a leak at the heater core fittings
Old May 2, 2016 | 09:55 PM
pjf1313's Avatar
pjf1313 is on a distinguished road
Hopefully RichPhotos is right, but. .
Do you have AC? That spot seems to be a coolant/anti-freeze leak from the heater core dripping out of the AC condensate drain hole.
I hope Rich is right for you..
P.J.
Old May 3, 2016 | 10:54 AM
I do have an AC. I checked the heater core fittings and saw no signs of leaking. If it is the heater core, could the hoses be disconnected from the heater core and spliced together to bypass it until I have time to replace the heater core? Would this also be a good test to see if the leak stops as well? That way I no for sure it's the heater core.
Old May 3, 2016 | 02:02 PM
richphotos's Avatar
You can bypass it for the time being, yes.
Old Jun 3, 2016 | 07:49 PM
Bypassed the heater core and the leak stopped.
Old Jun 11, 2016 | 06:55 PM
cleburne red's Avatar
Just don't forget you have it bypassed, and all of a sudden winter sneaks up on you! Did that one time in my '73. Finally got the core changed out in like January. I was FREEZING that year!
WalkGood
Sep 23, 2013 12:17 AM
Sturg
Oct 27, 2010 09:57 PM
ComputerNerdBD
Aug 7, 2009 12:54 AM
mikenisabel
Dec 20, 2008 10:29 PM
mane187
Oct 29, 2007 06:37 PM
