Coolant leaking
Old 12-04-2023, 01:28 AM
christine_208 will become famous soon enough
Originally Posted by Jmack
98 Blazer 4dr 4wd
Which components that were already damaged can be worsened by the radiator pressure test? The leak is where the short black hose with 90 degree bend connects to the other hose that goes to the top of the radiator in the photo in the link below. The connection is underneath the air intake.
4.3 Liter OHV 12-Valve V6 Engine for the 1998 Chevrolet Blazer #52202305 | GTCarLot.com
The coolant system pressure test will not harm your coolant components anymore than running the engine since the pressure at which the radiator cap releases excess pressure is the same pressure you will apply to the cooling system.
As for identifying where the leak is, you will have to be more specific. I would suggest taking a picture where the leak is located on your vehicle and including in the picture some way to definitively identifying the location such as pointing to it with one of your fingers or putting a piece of tape on the hose where the leak is.
GreenBlazer2002
05-19-2017 04:01 PM
Rww
11-05-2014 04:55 PM
Jlhazen
09-02-2013 08:29 PM
a_tack
08-01-2010 10:07 PM
Skeeter Cruz
03-04-2010 07:07 PM
Quick Reply: Coolant leaking
