Coolant leaking back on engine
Gentleman,
I though my S10 Blazer (1996 V6 4WD) had a radiator problem yesterday, white steam from under hood when slowing and stopped.
On inspection the radiator and hoses are OK, looking under the vehicle from behind drivers side tire, with engine idling I could see a thin but steady stream of coolant coming down from right above the back corner of the oil pan area.
Cannot see exactly where it's coming from yet, any ideas? I searched some threads and found one talking about freeze plug(s) leaking but it's been nothing but hot around here!
This is my first post...be gentle
could be the intake also. the engine is leaning back inside the truck a little bit so any antifreeze on top of the engine will roll out the back. try looking all around the engine on top and see if you see any wet areas
Corey Mondragon
01-04-2012 12:49 AM
mack89
23
01-01-2012 01:27 PM
bertrenolds
03-28-2011 12:04 AM
Skeeter Cruz
03-04-2010 08:07 PM
