Coolant Passages
Old Jul 3, 2009 | 11:17 AM
95redblazer's Avatar
95redblazer is on a distinguished road
Default Coolant Passages
I have a 95 Blazer, Vortec V-6 (W), and am in the process of replacing the intake manifold gaskets due to a leak. I have the upper plenum off, and manifold off and want to flush the coolant passages in the block. I removed the block drain from the driver's side and flushed both the front and rear passages and they drained thru the block drain. I added water to the center passage and noticed it wasn't draining to the block drain or anywhere else. Where does the center passage drain to? Thanks.
John
Old Jul 3, 2009 | 01:27 PM
The center port is a heat riser port (throw back from earlier engines) and is not associated with the cooling system.
Old Jul 3, 2009 | 02:43 PM
Thanks for the info. I assume the same port (center) on the passenger side of the engine is the same same thing - a heat riser port. The passenger side center port is almost completely plugged with carbon.
John
Old Jul 3, 2009 | 03:23 PM
Yep. Same thing. The heads are identical side to side.
AcerDeucerQ
Dec 3, 2012 06:29 AM
MrTwister
Jan 15, 2012 07:24 AM
Skeeter Cruz
Mar 4, 2010 07:07 PM
Colby 04
Jan 11, 2010 11:05 PM
creisenger
Apr 15, 2005 12:12 AM
