coolant plug(s) on engine block?
Old Apr 6, 2007 | 06:29 PM
kerander's Avatar
kerander is an unknown quantity at this point
Default coolant plug(s) on engine block?
I was trying to find the engine block drain plugs for the coolant on my 95 blazer, but I can't seem to find them [>:].Anybodyhave an idea of where to look from to see them (if they actually exist)? Haynes says under the exhaust manifold, but I don't see it.
Old Apr 6, 2007 | 06:37 PM
kerander's Avatar
Default RE: coolant plug(s) on engine block?
Ok, I was searching through some old posts - are these the so-called "freeze plugs" that are made to pop out in case the coolant freezes? I was just wondering because it seemed a coolant flush would be a lot easier with the block plugs out, but if that's what they are then I'm not going to mess with them. Anybody?
Old Apr 6, 2007 | 07:57 PM
pilgrim's Avatar
pilgrim is an unknown quantity at this point
Don't mess with the freeze plugs. They're a whole lot more trouble than they're worth. Flush using normal procedure as per the label directions on the flush kit and call it good.
Old Apr 7, 2007 | 03:19 AM
20Blazer00's Avatar
ORIGINAL: kerander
The plugs you are looking for are just above the motor-mounts in the middle of the block most likely under the "exhuast manifold" if you are looking from the front of the engine compartment...they also look like a 6 pointed bolt sticking out of the block.
There should be one on each side in the same areas...
Old Apr 12, 2007 | 04:29 PM
kerander's Avatar
Thanks 20Blazer00.
helo
Oct 29, 2019 07:56 AM
iamchevyman5
Nov 10, 2010 05:07 PM
lil_blazin
May 10, 2009 05:20 PM
N.alaska_blazer
Feb 23, 2009 01:31 PM
boulonman
Mar 5, 2007 05:10 AM
