Coolant Question
Old Sep 3, 2009 | 10:05 AM
jpmccr's Avatar
jpmccr is an unknown quantity at this point
Question Coolant Question
2001 Chevy Blazer 4X4, 127,000 miles. The radiator was replaced in March and everything seemed to be fine. Lately I have had to keep topping off the radiator. I am not sure what is going on or where this stuff is going. Checked the oil - clean and clear; hasn't overheated; no water vapor present in the exhaust; no visible leaks on the ground. I did find the overflow hose was not tight and I tightened the clamp. I am preplexed. Any ideas on where it is going??? Maybe I fixed the problem by tightening the hose clamp. . . .
Old Sep 3, 2009 | 10:09 AM
rriddle3's Avatar
Have a pressure test run on the cooling system and it will tell you where a leak is.
Old Sep 3, 2009 | 11:26 AM
Sisk's Avatar
You could also add the dye to the coolant. it will turn any leak neon and make it easier to see.
AcerDeucerQ
Dec 3, 2012 06:29 AM
Skeeter Cruz
Mar 4, 2010 07:07 PM
Jackrabbit
Jan 13, 2010 09:54 PM
jikastew
Jun 5, 2006 12:57 AM
smdepew1976
Mar 31, 2006 02:30 AM
