Coolant Sensor/thermostat?
Old Jul 26, 2017 | 03:54 PM
bryanw's Avatar
bryanw is on a distinguished road
Default Coolant Sensor/thermostat?
RPMs are stuttering/surging at highway speeds, check engine light code was for the coolant sensor. I replaced it but the surging is still happening. The wiring didn't look fabulous, I put a little electrical tape around a spot by the sensor so I don't know if maybe the wiring is bad. A mechanic told me to replace the thermostat. Any other suggestions? Thank you so much in advance for any assistance.
Bryan
UPDATE: Replaced the thermostat but nothing changed. Transmission fluid was low so I added some still no change. I think there may be a fluid leak, will investigate more tonight. The surging only seems noticeable at highway speeds when I ease up off the gas, on cruise control it's very obvious.
Old Jul 30, 2017 | 04:28 PM
joejiz's Avatar
joejiz is on a distinguished road
check fuel pressure? spark to each cylinder wire successful?
check wiring on coolant sensor routing back. a misfire was fixed on this board by someone else who noticed bad wiring with that sensor.
Old Jul 30, 2017 | 11:35 PM
bryanw's Avatar
Thanks for the response. It did seem that the wiring wasn't great when I replaced the sensor. Had a new fuel filter and pump installed 2 years ago but haven't recently checked the fuel pressure or cylinder sparks. I did have a random misfire code pop up last time I took it in to get tags but it never came back after it was cleared a few months ago. I will see if I can figure out how to check all that and go from there. Thanks again.
AcerDeucerQ
Dec 3, 2012 06:29 AM
getinmycarihavecandy
Jan 2, 2012 03:16 PM
ComputerNerdBD
Jul 10, 2011 12:54 AM
Skeeter Cruz
Mar 4, 2010 07:07 PM
nofear17bmx
Dec 6, 2006 09:00 AM
