Thermostat Sensor
Old Dec 5, 2006 | 09:28 PM
nofear17bmx's Avatar
nofear17bmx is an unknown quantity at this point
Default Thermostat Sensor
My temperature on my truck is wrong so I want to change the sensor that reads this. I understand it’s in a thermostat housing. My question is where is this? I think I know where it is, but some of you have said this is not it.
Old Dec 5, 2006 | 09:41 PM
magnum434's Avatar
magnum434 is an unknown quantity at this point
Default RE: Thermostat Sensor
The temp sensor should be in the front of the intake, the sender shold be in the cylinder head on the driver side
Old Dec 5, 2006 | 09:46 PM
Wait whats the difference between the sensor and the sender...what should I be replacing...gahhH! lol
Old Dec 5, 2006 | 11:42 PM
Chevy Lover's Avatar
The sender has one wire (probably green) and sends a signal to the gusge in the dash.
The sensor has 2 wires and sends a signal to the computer.
If your guage is inaccurate, it's probably the unit in the driver side cylinder head.
Put a bucket down to catch the coolant that will leak out when you remove the sender (with a 3/4" deep socket)
[IMG]local://upfiles/2910/E69EB9C9BA234C1AAF15FCB6946BA51C.gif[/IMG]
Old Dec 6, 2006 | 12:33 AM
Thank you chevy lover, so the sender is the sensor that tells me the temp on my gauge, and the sensor is a sensor that tells the computer the temperature. So how do I know the "sensor" is correct also and not inaccurate considering the two are separate. I can only tell that the sender is wrong...would I need to get a code reader to read what the computer is getting for a temperature?
Old Dec 6, 2006 | 01:00 AM
I don't believe a code reader will tell you the temp that the computer sees. You would need a scanner for that.
Old Dec 6, 2006 | 01:04 AM
I still feel a little confused. You guys want me to replace the sender (the sender is what tells me the temp via guage on my dash) but how do I know the sensor is correct and the computer is getting the correct temperature?
Old Dec 6, 2006 | 01:07 AM
ORIGINAL: nofear17bmx
Let's start from the beginning, maybe I missed something.
Why do you think the "temperature on your truck is wrong"
Old Dec 6, 2006 | 09:00 AM
My gauge reads 150 degrees once it is fully warmed up.
getinmycarihavecandy
Jan 2, 2012 03:16 PM
GM hater
Jan 9, 2010 02:32 PM
theeviltwinn
Oct 23, 2009 06:37 AM
daniel010
Feb 2, 2009 06:50 AM
Spartan66
Jul 11, 2008 02:34 PM
