Coolant Smell?
Old Sep 17, 2018 | 07:46 PM
lathechips's Avatar
lathechips is on a distinguished road
Default Coolant Smell?
It rained & got cool enough to turn heater on the heater this morning. Got a slight smell of coolant & windows fogged up. after driving around I didn't see any coolant leaks around the motor or on the ground. If it is a heater core, anything I should know about testing or screwed & having replacing it? Thanks in advance to who reply.
Old Sep 17, 2018 | 08:33 PM
Sounds like heater core to me... When mine started leaking I got a strong antifreeze smell in the cab with anything blowing out of the vents. It's not a super hard project to undertake, but it takes the better part of half a day to get done correctly and not break or misplace anything.
I went as far as completely opening up the the EVAP housing and wiping it down with thinner on a rag to get rid of any antifreeze residue
Old Sep 18, 2018 | 01:05 AM
G0LFADD1CT's Avatar
G0LFADD1CT is an unknown quantity at this point
Classic description of a heater core leak. I speak from experience. Sure wasn't as easy to replace as the one in my '77 Chevy C10.
Old Sep 18, 2018 | 11:02 AM
Considering what a pain it was to replace the blend-door actuator, what are people's thoughts about also replacing it while the dash is off?
Old Sep 18, 2018 | 02:10 PM
GreenBlazer2002's Avatar
1. How much is the part?
2. How difficult is it to replace (while everything is apart)?
3. How prone is it to failure?
I owned several S series since the 90s abd I've never had an issue with that particular part.
Old Sep 18, 2018 | 03:28 PM
It is not very expensive but it is a bear to get out through the glove compartment opening. It is prone enough to failure to have several Youtube videos posted online on it.
Old Sep 19, 2018 | 04:28 PM
GeorgeLG's Avatar
Just make sure that the replacement is not of inferior quality compared to the functioning oem part.
George
BeaterJimmy
Dec 22, 2018 09:12 AM
blazerguy2
Mar 11, 2017 06:24 AM
Tuna
Dec 19, 2014 12:05 PM
NavyAirframer
Feb 7, 2011 11:01 PM
RomanCatholic
16
Sep 1, 2009 10:47 PM
