Coolant Temp X 2 readings
1995 gmc jimmy 4.3 l vortek 4wd
Seeing that my Engine Block has two similar water jacket temp sensor threaded holes. Similar locations on each side of the block.The stock config is to use engine left side threaded hole for H2O temp sensor.
Right side has a freeze plug or bolted stopper.
I would like to add a second sensor to the Right side.
With this second H2O sensor , would this give any early indication as to a Head Temp variance between te two heads ?
zakm0n
01-09-2011 07:31 PM
Bad Ramer Jamer
09-16-2008 10:32 AM
