Cooling System Issues (P0128, coolant loss)
Old 10-06-2018, 11:07 PM
G0LFADD1CT's Avatar
G0LFADD1CT is an unknown quantity at this point
I'm sure you probably have but did you inspect the weep hole on the water pump? I kept losing coolant at about the rate your describing and for the longest time I couldn't figure out why. Then one day I was doing something in the engine bay and noticed what looked like a very small wet spot under the weep hole. Changed out the water pump and no more coolant loss.
  #22
Old 10-07-2018, 09:56 AM
christine_208 will become famous soon enoughchristine_208 will become famous soon enough
Thanks for posting the update. I'm so appreciative when people do that I always like to post and send a thanks!
As for the leak, I heard of someone having a pin hole leak that only let water out when the system was hot/pressurized and that it leaked onto a hot surface that caused the water to evaporate. Have you tried pressurizing the system to look for a leak? I guess this would also apply to a leaking LIM gasket.
  #23
Old 10-07-2018, 05:25 PM
2001ZR2's Avatar
I had a crack in a plastic tank that only showed up when the truck was running and very hot. Should have found it when you pressurized the system so I would look at the cap and/or the water pump.
  #24
Old 10-12-2018, 08:57 AM
spnzz6's Avatar
spnzz6 is on a distinguished road
when tightening the LIM bolts there is a very specific procedure on these engines. Including a final extra turn on one of the front bolts on the drivers side. I think it is the second one back. In all my years wrenching I never would have known if my brother hadn't given me the repair manual from when he owned one. Hope this helps.
  #25
Old 10-12-2018, 09:03 AM
spnzz6's Avatar
I also forgot to mention that a LIM gasket can leak internally to an intake port and the coolant would probably not make it into the oil. It would just blow right out the exhaust.
Fatguy9
13
02-08-2016 10:00 AM
Tuna
11-17-2014 04:57 PM
clebrowns89
01-06-2012 06:22 PM
wglassbrook
10-14-2009 04:18 PM
chevblazer02
12-05-2006 08:59 PM
Quick Reply: Cooling System Issues (P0128, coolant loss)
