corroded contacts in distributer cap
Old Jan 4, 2011 | 12:15 AM
3D_Illustrator's Avatar
3D_Illustrator is an unknown quantity at this point
Default corroded contacts in distributer cap
I got corrosion on the contacts of a 6 month old Wells brass contact distributor cap . Would a different brand work better? What is a recommended as best brand distributor cap for my 1997 Blazer?
I have replaced the seal under the distributor cap to keep crankcase gas fumes out, but still have the problem.
Could the problem be caused by a weak coil causing poor spark? The truck runs OK when started, but is having a cold start problem intermittently.
Old Jan 4, 2011 | 05:43 AM
Peru Motors's Avatar
Peru Motors is an unknown quantity at this point
you could try an ACDelco cap plus make sure to put some Di-electric grease in each terminal. Jerry
jasonscottclack
May 23, 2011 06:59 AM
sam24fan
May 14, 2010 08:39 PM
thehustler211
Apr 21, 2009 01:43 PM
justin1795
Mar 27, 2009 07:55 PM
