couple of questions about my 96 jimmy
Old Jan 28, 2010 | 07:24 AM
thenewguy's Avatar
thenewguy is on a distinguished road
Default couple of questions about my 96 jimmy
Ok I have a 96 'high rise' s15 jimmy . I have 3 questions for starters,
1 check engine light randomly comes on I had it scanned and the results were p040 evap system and p0700 transmission control system. It does shift hard between 1st and second 2nd.
2 daytime running light issue. When the relay in the glove box is plugged in I have daytime running lights on, when I turn the headlights on I hear the crazy squeeling sound coming from that relay box in the glove. with the relay removed I only have 1 high beam. The bulbs are all good and high beams both work with relay plugged in. Any ideas how to get this working normally?
3 4x4 related question. When I was stuck on an icy rd I stopped put the truck into 4 whl high and nothing happened. It sounded like it shifted, indicator lights all lit but no front wheel movement. After I backed down the road turned around to go a diff direction, after going about 100 ft the 4x4 kicked in and worked. It did not go off when the button was pushed though. Now when I try to use it, it sounds like it shifts, lights light up but no wheel movement. Where should I start looking?
thanks all for your input sorry for the long post.
Old Jan 28, 2010 | 06:15 PM
thenewguy's Avatar
any ideas???
Old Jan 28, 2010 | 06:18 PM
Patience...
Those codes are meaningless since they are not complete. Check out the DTC section of the Tech Article (DIY) section for a listing of codes that have been posted.
As far as your headlights & DRLs go, have you tried replacing the relay?
There are many posts on 4wd issues. Check the link in my signature for some ideas.
PiKapp
Jan 20, 2007 01:45 AM
mx416
Dec 24, 2006 08:31 PM
Jackal
Engine & Internal
Dec 6, 2006 10:40 PM
jpap
Oct 25, 2006 01:22 AM
Benado
Oct 23, 2006 12:16 PM
