Courtesy light mounting location
Old Dec 7, 2008 | 04:08 PM
Ted's Avatar
Ted
Ted is an unknown quantity at this point
Default Courtesy light mounting location
So I spent the afternoon replacing the combo switch on my daughter's 98 Blazer. A couple of great tips from this forum made the job easier and saved my hunting down some sockets for the single external torx screw.
Anyway, when I remover the filler panel, a courtesy light dropped down. As I was putting things back together, I looked and looked for a mounting location, but couldn't find one. This is, of course, the driver's side.
Can anyone tell me where that courtesy light should mount?
Thanks.
Old Dec 7, 2008 | 06:33 PM
Peru Motors's Avatar
Peru Motors is an unknown quantity at this point
Default RE: Courtesy light mounting location
should be a 7mm bolt holding it in place, under the dash-look up to the right of the e-brake handle, above your foot brake, mounted in the darker colored plastic under the actual dash. There should be a void, cavity where you can see the spot. JP[&o]
Bry85
Mar 13, 2012 08:46 AM
Thogert
Jul 13, 2011 06:02 AM
1997 red blazer
Feb 10, 2010 01:10 PM
skybolt31
Nov 29, 2009 03:10 PM
NTL1991
Dec 29, 2008 03:31 PM
