cpi problem not a problem!!!!!
Old Aug 2, 2009 | 10:09 PM
Confuused69's Avatar
Confuused69 is on a distinguished road
Default cpi problem not a problem!!!!!
Well i bought this 95 jimmy for 600 bucks, and its a beautiful truck. Damn thing ran fine then once i got it home, it idled so rough and sputtered. so i did new plugs, wires, cap, rotor, fuel filter, k&n filter and oil. it improved but not alot. Then i replaced egr, and cleaned all of the sensors on the manifold with injector cleaner..... nothing worked, so after hours of reading on this ba forum, i knew it was my cpi. I knew the spider was screwed. So today i took off the plenum just to check before i spent 300 bucks.... it wasnt the spider.... it was this - - - -
Notice the black fuel lines on the fuel lines coming in. This next pic shows that the black fuel lines actually rubbed the other ones causing a small slice. That is what cause my rough idling. So i spent 50 bucks on new lines, and im a happy man. Im glad I read that taking off the plenum and letting your fuel pump run to check for leaks, cuz i would have been ufked outa 300 bucks..... Hope this helps someone
Old Aug 2, 2009 | 10:17 PM
volfan4's Avatar
volfan4 is an unknown quantity at this point
lucky you!!! cool deal too.
Old Aug 2, 2009 | 10:24 PM
86Blazer4x4's Avatar
86Blazer4x4 is an unknown quantity at this point
might be having to take a look at this soon hopefully the new plugs and wires take care of it. how many miles to you have on your blazer?
Old Aug 2, 2009 | 10:27 PM
theres 140000 miles on it. But it was poorly maintained.
Old Aug 2, 2009 | 10:29 PM
huh mine was owned by the state and only has 77,000 miles on it.
Old Aug 2, 2009 | 10:35 PM
oh wow. Is yours doing the same? Im sure you know, but check your egr. Its simple and easy. And also causes rough idle. I took mine out and had a carbon rock wedged in mine. so i got a new one, but it was 100 bucks. Then I took carb cleaner to the old one and cleaned the **** out of it, put it back on and it worked just like the new one. Then took the new one back to discount and got my money back!! I like it easy.
Old Aug 2, 2009 | 10:44 PM
i did that with mine. mine was just full of carbon so i sprayed it out cleaned it up put the new gasket with the screen in it. im going to try other things like a full tune up. on her. the thing is once i hit the gas it fine to just go and cruise just only sitting at an idle.
Old Aug 2, 2009 | 10:49 PM
yeah, thats the same with mine. After I put a new fuel filter in mine, it was like 60% better, it stopped shaking my truck but it still gurgled at idle. If you can smell gas in the front of your truck during or after it is running. You definately have a problem. Just take off the plenum, it took me about 10 minutes not even, and check it. And a new gasket is 11 bucks. So its pretty cheap.
Old Aug 2, 2009 | 11:01 PM
oh i dont smell gas or anything.
Old Aug 2, 2009 | 11:09 PM
It still wouldnt hurt, but just wait to do it after you do a full tune up. def, replace your fuel filter. It made a huge difference. Let me know what it was when you figure it out. These ideling problems are a big issue with this motor.
