cracked exhaust
Old Apr 28, 2009 | 09:37 PM
Biohazed's Avatar
Default cracked exhaust
ok well I had to replace the Fuel pump on my '95 today so I took it into work so i can abuse err use the lifts and air sources at work plus all my tools are there. anyway after i was done putting the tank back in I happened to take a look at my exhaust and noticed a 2-3 inch crack formng in the tail section behind the muffler on the bend that goes around the rear axle. does anyone know a cheap temporary fix that can hold my tail together until I have time and the money to get it replaced?
Old Apr 28, 2009 | 10:07 PM
portcqb's Avatar
portcqb is an unknown quantity at this point
If you know someone with a welder than that would be a permanant fix, as for a temp fix they make some exaust tape that will seal it for awhile.
Old Apr 28, 2009 | 10:08 PM
Swain's Avatar
Swain is an unknown quantity at this point
Your favorite soda can of choice and some tight hose clamps. Turn it inside out if you don't want it to look reeeeeal ghetto
Old Apr 29, 2009 | 12:26 AM
bandidolenny's Avatar
Glad to hear you got your fuel pump issue taken care of. I would do some JB Weld, then the exhaust tape and over that I think a beer can would look cooler than a soda can.
Old Apr 29, 2009 | 12:41 AM
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
lol +1 on the beer can.
Old Apr 29, 2009 | 08:35 AM
If it is just cracked at the seam, you should be able to weld it back up. If it just wants to blow through with the welder, make a patch out of an old section of pipe cut to cover the crack.
Old Apr 29, 2009 | 06:19 PM
Biohazed's Avatar
its not at a seam its actually in the pipe itself. I took a picture showing most of the crack you you guys have a idea
Old Apr 29, 2009 | 07:44 PM
Oh damn. Cut it off and put a new tail pipe on it.
Cidium
Jan 22, 2011 11:56 PM
89 Blazer Lebanon
Mar 1, 2010 02:10 PM
scottyk
Feb 28, 2007 09:45 AM
jp
Jun 26, 2006 01:30 PM
Dizgt
Apr 8, 2006 10:59 PM
