Cracked lower intake manifold?
#41
Some progress tonight. I've had the passenger drain open for several days. It still had water in the water pump opening, so I dug around with a coat hanger. Got what seemed to be wet cement mix out at first, then what appeared to be mud. Finally the clean water that had been sitting on top of it.
Ran a gallon of water through both sides of the engine, from the water pump openings. The water out of the drains came out clean. Probably do one more on each side tonight just to be thorough, then maybe tomorrow start putting it back together. I still need several gaskets, an oil change, and a new starter.
They've had us on 14 hour shifts, seven days a week this past week, and probably for at least two more to come, or else I probably would have had this done by now. Oh well, the double time sure will come in handy!
#42
I think it's fixed. Got it back together last night, and went for a half hour test drive. It never went over 183*, with the 180 thermostat I have in it. I'll want to drive it some more before I full trust it.
Right now I have straight water in it, I'll give it a few days and drain that and put anti freeze in.
#44
I'm gonna call it fixed. I've drove it to work and back, plus around town for a couple days now, and it's never gotten above 189*, with a 180* thermostat. I did notice my new radiator cap is leaking, so I'll have to get another one of those. Also, I have no heat! And it's starting to get cold!
I have to drain the system, anyway, since I have straight water in it, so I'll try and flush out the heater core while I'm there.
I guess the moral to this story is, if you don't open the block drains, you aren't really flushing out the whole cooling system. Thanks to everyone who helped out and offered advice
#45
#46
Remembering back to the old brass radiator and heater core days, we used a Prestone Radiator Flush that really knocked out the calcium and lime from running tap or well water as a coolant. EPA and aluminum cores have eliminated that as a way to remove the lime. I've been successful unclogging a heater core in my second-hand 2000 by disconnecting both heater hoses at the engine ends and poring white vinegar into one of the hoses with a small funnel. 10-15 minutes and then back flushing will get a lot of the lime cleared out. I did a second treatment and then the water came out clear and with good flow. A glass full of water and four table spoons of baking soda neutralized the remaining vinegar in the heater core. Of course, the best cure is prevention........ always use distilled water instead of tap water in your radiators and batteries.
I did this because my core was 90% stopped up and a last ditch effort before replacing the core.... This may have been extreme and there may be better methods. I would be interested in learning what has been successful for others.
pshtr
04-16-2012 09:54 AM
darin89
08-18-2011 03:07 PM
ded2klf
11-29-2010 10:15 PM
vagnozzi
09-14-2007 08:40 AM
