Crankshaft position sensor relearn question
Feel like I opened a can of worms here. Long story short I went to do front suspension and steering parts replacement and found axle bearing bad so removed axle and had bearings and seals done at shop. Found oil pan leaking at front lower seal so thought pan gasket should be done while axle was out. While cleaning block surface found lower timing cover is cranked. So now I guess ill be replacing that too.
How long can truck be driven before getting relearn done? (will have to get to a shop when finished.) Also anything I should know about getting into doing the timing cover replacement?
If the crankshaft position sensor and or timing cover is moved, removed, replaced, or disturbed in any way, the relearn must be performed. If not performed, the PCM will use the old relearn data which is now incorrect. The engine will still start and run, but ignition timing, injector timing, cylinder misfire detection and accurate identification will all be incorrect. The sooner you have the relearn performed, the better. It will not damage the engine if you don't have it performed.
