crankshaft seal oil leak
Old Apr 27, 2012 | 08:58 AM
Klturi421's Avatar
Klturi421 is on a distinguished road
Default crankshaft seal oil leak
I recently replaced my timing cover and harmonic balancer. During the installation process I did not use any grease or lube aside from RTV on the keyway. Now almost a week later I have an oil leak coming from the crankshaft seal. Forums that I have been reading recommend some kind of lube or sealant.
What am I supposed to do here? What materials should I apply? Should I replace the seal again?
Old Apr 27, 2012 | 09:19 AM
pettyfog's Avatar
Yep. Running a seal dry will pretty much ruin it. You could try putting lube on it but you'd still have to pull the pulley. And then no assurance it wont end up leaking just as much.
Old Apr 27, 2012 | 10:19 AM
Klturi421's Avatar
So the best thing at this point would be to pull the pulley and the seal, replace the seal and use some lube.
Is there a specific kind I need to use? Anything else I should put on the seal or the balancer?
Old Apr 27, 2012 | 10:34 AM
pettyfog's Avatar
I always used just a little permatex sealer on the outer mating surfaces. Plastic..then rtv probably better.
On lips of seal and pulley area, just oil is fine.
Seems it would be a tough job getting seal out of cover, though.
Old Apr 27, 2012 | 10:45 AM
Klturi421's Avatar
Is there anyway to save the current seal? Would using the permatex help or am I in for having to get a new one?
Edit: here in a few minutes I am going to try and upload a picture from my harmonic balancer where it meets the seal. I can see silver from the balancer but I'm not sure if I am supposed to.
Here is that picture.
Old Apr 27, 2012 | 01:56 PM
chcknugget's Avatar
chcknugget is on a distinguished road
It's hard to tell what silver you're talking about, but I'd replace the seal for sure- it is less than $10 last time I checked... And if it's leaking now it is almost certainly leaking because it is damaged. Be careful removing and installing the seal bc the chain cover is plastic and replacing the cover is an even bigger job. Check the seal surface of the damper for damage before reinstalling.
Old Apr 27, 2012 | 02:30 PM
Klturi421's Avatar
Does the cover actually contain oil or is it just a dust cover?
Old Apr 27, 2012 | 02:58 PM
chcknugget's Avatar
Lol, well yes, it's supposed to contain oil.
Bluebeastblazer57
Aug 11, 2012 11:05 PM
ComputerNerdBD
Aug 9, 2011 08:04 AM
kieron
Apr 18, 2011 10:53 AM
blazinloud
Aug 30, 2010 11:44 PM
ebristol
Apr 1, 2008 04:53 PM
