Crazy oil leak
Old Apr 21, 2013 | 08:22 PM
bassson's Avatar
bassson is on a distinguished road
Default Crazy oil leak
hey guys, just seeing what other people think....
so I have a pretty nasty oil leak from the back of my engine. My thoughts are that its coming from the backside of the intake manifold gasket. I replaced the gasket last year, and had an oil leak shortly after. Im thinking its due to poor installation. Its impossible to see the leak without pulling parts just seeing what everyone else thinks. Im just hoping its not the rear main.
Old Apr 21, 2013 | 09:00 PM
If you remove the distributor you can inspect the rear RTV seal. When the intake is installed, if you slide it to line up the bolt holes, it will push the RTV out of position and it will leak.
Old Apr 21, 2013 | 10:12 PM
bassson's Avatar
cheers, ill try that tomorrow, thanks for the quick response!
Old Apr 22, 2013 | 02:14 PM
abig84's Avatar
check your pcv system too, make sure its not clogged up and its got pleanty of vacuum pulling through it. i ended up having to do mine twice due to this, blew the rear silicone bead out like a hour after i installed it. way easier the second time around though
Old Apr 22, 2013 | 04:56 PM
bassson's Avatar
thanks abig84! i just took a look, and i can see a small oil leakage coming from the pcv system indicating its clogged up (im assuming). Thanks for the info!
lostrealist
Oct 12, 2012 07:07 AM
BubbaBrooks
May 18, 2011 08:38 PM
mudd
May 14, 2008 12:02 AM
TAZ454
Jan 28, 2008 10:11 AM
