cRAZY Squeaking
Old May 8, 2007 | 01:00 PM
Miller's Avatar
Miller is an unknown quantity at this point
Default cRAZY Squeaking
New to forums and didn't know if any of your blazers have a squekin problem[:@]
Its a 96 s10 blazer, and the front is squeakin bad, Ive greased it uo and it comes right back. The sqeauking only happens when the tires are straight. When the tires are turned it is quiet, or even when it is on an incline.
Any help would be greatly appreciated.
Thanks[8D]
Old May 8, 2007 | 05:37 PM
20Blazer00's Avatar
Default RE: cRAZY Squeaking
Check all the rubber bushings in the front end and lube them up with a silicone based spray on grease...do one at a time to find out which is the problem. start with the shocks then control arm upper then lower then move to the swaybar bushings...also check the front driveshaft CV boots for wear and grease coming out...
Old May 9, 2007 | 06:02 AM
DINO55's Avatar
DINO55 is an unknown quantity at this point
"The sqeauking only happens when the tires are straight. When the tires are turned it is quiet, or even when it is on an incline."
If your driving yourtruck down the road and thissqueaking is going away as you turn the wheels, you may be hearingfront wheel bearings...
kennysgirl
Aug 11, 2006 12:48 PM
jumper02
Jun 8, 2006 12:09 AM
blazerman
May 29, 2006 10:39 PM
tpendergraft85
Feb 17, 2006 07:10 AM
