CSFI spider sprays on fuel pump prime?
Old Jul 26, 2016 | 12:12 PM
latlog7's Avatar
latlog7 is on a distinguished road
Default CSFI spider sprays on fuel pump prime?
Quick question here:
For the central sequential fuel injection spider, is it supposed to spray fuel out of the fuel injectors when the key is first turned to the run position to activate the fuel pump? Just curious before I actually do the leakdown test. I cycled the key to the run position about 3 times and no fuel came out of any of the injectors
Old Jul 26, 2016 | 12:17 PM
Racer_X's Avatar
Racer_X is on a distinguished road
No. The fuel injectors should only open when the engine is cranking.
Priming just pressurizes the system so that when you do crank it, the correct amount of fuel will come out when the PCM pulses the injectors.
Old Jul 26, 2016 | 03:47 PM
latlog7's Avatar
Oh okay. Thanks for the info, its always appreciated!
ClarusWorks
24
Aug 26, 2012 11:21 AM
DJMannyD
Aug 13, 2010 08:39 PM
chelios#24
Mar 28, 2010 02:28 PM
ArizonaMN12
Feb 23, 2009 06:32 AM
