Current All Aluminum Radiator Options?
Old Feb 14, 2019 | 11:14 AM
Originally Posted by jimspahr@msn.com
When you install a two electric fan set up on a Blazer with the stock mechanical single cooling fan, it would seem you would have to have some elec. connection to interface with the engine cooling system to turn the elec. fans on and off. Is that correct ? How is it done ?
In principle, this is my understanding of how it is done. In the particular case of our Blazers, I would not know but I'm sure it has been done. One issue is to find a +12V source that is only on when the ignition is on. But as we all know, you cannot blindly start splicing into our electrical harnesses without potential damage to the ECM or BCM.
Originally Posted by cleburne red
Not sure. Maybe it comes with a temp sensor of its own it uses to turn them off and on?
I've seen a video on the wiring up of such a system but it was on a carbureted sbc and they screwed in a dedicated temperature sensor into an unused threaded port on the intake manifold.
Old Feb 16, 2019 | 03:56 PM
So after much research and calculating, I've learned that just about every aluminum radiator available for our Blazers (and perhaps most other vehicles) is made in China and sold under many different brands on Amazon and eBay.
I've also learned about the construction of aluminum radiators vs the older copper/brass radiators with which I am more familiar. With aluminum, the number of cores is not so important as much with copper radiators as that with aluminum the tubes can be much wider. It is the total surface area and airflow through the radiator that matters so that all things being equal, it is actually better to have fewer cores. Thus it is not enough to just count rows and say more is better. These links helped me understand this: http://www.griffinrad.com/tube.php, https://www.speedcooling.com/blog/page/2, Speed Cooling Blog | ENGINEERED COOLING PRODUCTS | Page 6). There is also this:
So after eliminating the many suspect radiators from consideration because they had questionable origins or with more cores than necessary, I narrowed my consideration to these four:The first two (Radiator Express and Engineered Cooling Products (speedcooling.com)) are all aluminum with the later two being the composite aluminum core with plastic end-caps.
In addition to apparently being from quality manufacturers, these all would appear to have increased cooling capacity over OE style by virtue of having thicker cores and more tubes. The one I would guess would have the best cooling, by a large margin, is the one by Engineered Cooling Products. Unfortunately this has been discontinued. The other aluminum one I don't think is necessarily sold by Radiator Express so I'm not sure of its origin. However, in terms of size of the core and number of rows of tubes, the last two are potentially as good as or better than the Radiator Express one. The core thickness of the Radiator Express one is 1.25" whereas the Mishimoto and Keystone radiators are 1.375" thick. (The OE radiators have cores that are listed as either 15/16" or 1".) Also, the Mishimoto and Keystone radiators have 39 vs. the 33 rows as used in the Radiator Express one as counted from from top to bottom.
I suspect that the Keystone one, that appears to only be sold by Advance Car Parts (Car Quest), is a re-branded Mishimoto. With all that in mind, I'm thinking the Mishimoto is the one to get.
Does anyone have any experience with the Mishimoto ones?
Old Feb 16, 2019 | 08:24 PM
Rock18's Avatar
Rock18 is on a distinguished road
Got curious so I did some digging. The brand reffered to as "Keystone Collision" on Autozone is as best as I can tell acutally Keystone Automotive Operations, Inc., is owned by LKQCorp, which is a distributor of parts but not really a manufacturer from looking at their 10K. Autozone does indeed appear to be a primary online retailer with the most web presence but much of their business appears to be commercial B2B (repair shops, fleets etc.) and regional retailers like A&A Auto Stores.
Mishimoto appears privately held so there are no financials to look at for clues. But although they seem to do some actual R&D design/engineering work, they don't appear to do their own manufacturing either. There might well be some overlaps in their supply chains (in other words, made by or shared components from the same supplier(s)) but strictly speaking it's doubtful the Keystone is simply a "re-branded Mishimoto."
Despite being identically dimensioned as best I can tell, there's at least one difference. The fittings on the Mishimoto appear gold-toned (brass?) and the Keystone silver. Not that this makes a bunch of difference in performance or reliability necessarily, just pointing out there are differences beyond simple rebranding alone.
The Mishimoto has a limited lifetime warranty, the Keystone a 5-year. That would probably be the deciding factor for me in favor of the Mishimoto, especially since it's cheaper too.
Old Feb 16, 2019 | 09:41 PM
Wow, and I thought I was pretty good at internet research! What you mentioned about the warranty is a good. Thanks for your posting.
Old Feb 18, 2019 | 01:36 PM
Mike.308's Avatar
LOL on that video.
Yeah, I can say that from my experience, Chinese follow the same route no matter how big contract they get. The routine is : NO F* RETURNS. I support a client, who used to make a $100k deals and even then, they prefer to send someone to do fixes here in Poland than collecting back the crap they've produced.
On the other hand, I remember we had an electronic project once to be installed on board of a ship while her shipyard and getting our parts through the border via customs was enormously long and expensive. Even due to fact, the agency was in relation to the governing party (like every major business there). I take it that way - governing party doesn't want any goods to be imported and maximize the export. With no exceptions (including warranty cases).
Old Feb 18, 2019 | 04:44 PM
So regarding Radiator Express, I expressly asked them where their radiators are made the they avoided the question.
Me: "Where is this radiator made? SKU: 226401 Also what are the size of the core tubes. Thanks"
Radiator Express:
"Hello,
All of our parts meet and exceed the O.E.M. (original part) dimensions. Please call us directly
to speak to one of our knowledgeable sales representatives for price and availability.
Best Regards,
Radiator Express
Old Feb 22, 2019 | 08:23 PM
Update: I ordered the Mishimoto radiator from Jegs because after a bit of research it looked to have an even better warranty than the Keystone. Well it arrived damaged, FedEx really tossed it around with holes being made in the box by the water inlet and outlets. The overflow connection was broken off along with the "wings" for the drain spigot.
Perhaps worse was that the radiator that I was so happy to have found because it was advertised to have a thicker core of 1 3/8" turned out to have a standard 1" core. I actually had checked the Mishimoto.com website to double check so I thought this was good data. Guess not.
So now, I need to decide if I want to get a radiator from Autozone or O'Reilly's with the standard core of 1" or hope that the Keystone one actually has a thicker core for more cooling.
Ugh... I need a beer.
Old Feb 23, 2019 | 03:35 AM
Mike.308's Avatar
Oh, how I evaluate my national supplier now, for bringing me the radiator and the a/c condenser in a perfect shape.
As for cooling efficiency a nice research might be done on that. What I've learned while working on a sea vessel engines, the engine blocks are equipped with two circulation circuits: high temperature (HT) and low temperature (LT). Similar as in cars. The boiler steam is heating the water in HT via heat exchanger, so that the cooling inlet temperature reaches 90 degrees of Celsius. The temperature is measured then on the block outlet. It should not differ from the inlet more than a 5 degrees (while the blocks are huge size). So, in fact, even, when the engine is shut, the block is being kept warm. A rule is You never ever cannot crank a cold block engine. Then, when the engine starts running, the temperature in HT is increasing due to a heat dissipation in the cylinder's jackets. So, the heat exchanger in between HT and LT acts a three-way valve in order to cool down the HT media with LT if necessary. The role of a three-way valve plays a thermostat in Blazer. It sends a HT core coolant to the LT section with a radiator and a fan. So, as far, as the thermostat isn't over regulated (fully open) and the temperature of the engine block isn't increasing above setpoint, the cooling efficiency is OK.
Old Feb 23, 2019 | 05:30 AM
Rock18's Avatar
Well, that's disheartening, if for no other reason than I had already saved the Mishimoto to my Amazon "stuff I want for my Blazer if/when the time comes" wishlist.
It might be worth engaging Mishimoto directly if the dimensions are off. They still list the core thickness @ 1.375" (1 3/8") on their product page for it. It's quite likely though that the best outcome you might get might be an eventual correction to the description to 1".
I kind of doubt there's much difference between the Keystone and the Mishimoto either. If it was offered in stock locally at Advance I'd just go take a look for just argument's sake but it's ship-to-home only. If you order keep your fingers crossed, and make sure you've got an airtight retailer guarantee and a credit card guarantee to fall back on in case you need to do a chargeback.
In fact, at this point I think I might be inclined to go for ACDelco (again) the next time I need a radiator if we're already talking plastic tanks anyway.
Old Feb 26, 2019 | 02:48 PM
Yes, it was disheartening. Because I really needed to get the radiator replaced, I ended up getting one from Autozone. It was their Duralast Radiator which turned out to be a Spectra Premium Radiator. (with a 1" core of course!)
The only option for a reasonably priced domestically made all aluminum radiator has discontinued making them. (speedcooling.com) A custom could be made but that is way too expensive. I also considered one of the ones from Champion but none of theirs had the connections for the remote engine oil cooler. To add a separate engine oil cooler would have cost a couple hundred dollars more, not including the hassle of having to plumb and mount such a cooler.
I have since sent an email to speedcooling.com to tell them that I think there is still quite a bit of interest in their product for our Blazers. We'll see if they start making them again.
