CV Axle 3rd time replacing
Old Apr 22, 2009 | 07:36 PM
WolfPack's Avatar
Originally Posted by Captain Hook
Just because some company makes a part, doesn't mean it's going to work without consequences.
Old Apr 26, 2009 | 08:16 AM
nonstop's Avatar
nonstop is an unknown quantity at this point
Soo...I can lower the front, put new cv axles in, coat the boots with silicone, then probably have the tires hit, so install a body lift.
or Sell it....For sale 98 Chevy Blazer with 2in RC lift $4000.00!!
http://orlando.craigslist.org/cto/1135287718.html
Old Apr 26, 2009 | 08:23 AM
Johns1987Blazer's Avatar
Johns1987Blazer is an unknown quantity at this point
I am a commercial parts pro at Advance Auto Parts and have seen quality go downhill the past few months. My question to you is, are you getting new axles or remanufactured? The new axles tend to hold up better which is what I replaced with on my 87.
Old Apr 26, 2009 | 12:42 PM
nonstop's Avatar
brand new
Old Apr 26, 2009 | 03:10 PM
bandidolenny's Avatar
Since I cranked my t-bars all the way down I have not had a vibrations or problems like in the past. My front tires rub a little on the rear of the front fenders when hitting a pretty big bump at full crank. A sawzall would solve this but it really doesn't bother me all that much. I believe a 2" body lift would solve your problems.
Old Apr 26, 2009 | 09:34 PM
New, used, remanufactured, rebuilt, it doesn't matter; If front chassis ride height is out of factory specs, (too high or too low), the joints will wear out prematurely, guaranteed!
Old Apr 27, 2009 | 12:44 PM
You are sorta right... CV shafts are designed to operate within a range of motion. It is possible to operate in the "upper" range of intended motion on IFS trucks without undue wear and tear. The longer the shaft the more range of motion that can be achieved, hence the wider track on the ZR2's.
The proper way to lift an IFS truck is to lower the front differential so as to stay in the proper "range of motion" with the CV shafts. Therefore it is possible for the ride height to be "out of factory specs" and still operate as intended. Or better depending on what you are trying to do with it.
Old Apr 27, 2009 | 02:02 PM
WolfPack's Avatar
Or get custom CVs made
Old Apr 27, 2009 | 02:14 PM
I actually checked into custom made CV shafts but the price was gonna be around $1300 each with no guarantees.
Old Apr 27, 2009 | 05:09 PM
What about all 4 ball joints, both outer tie rod ends, and both differential pinion angles? All of them are adversely affected when ride height is out of spec. If you want your Blazer to look bigger, park it next to a Chevy Tracker, or a Kia Sportage
