in dash brake lights wont go off
Old Mar 17, 2008 | 05:28 PM
DPL33's Avatar
DPL33 is an unknown quantity at this point
Default in dash brake lights wont go off
i have a 99 blazer and just recently i noticed that in dash parking lights will not go off. i need to press the brakes all the way to the floor in order to stop. and to make matters worse, i snapped the cable for the hood release the other day! i filled the brake fluid, and the brakes got a little better (they dont go all the way to the floor now) should i just bring into the shop or can this be fixed by myself? thanks
Old Mar 18, 2008 | 12:09 PM
portcqb's Avatar
portcqb is an unknown quantity at this point
Default RE: in dash brake lights wont go off
Just a chance is your light dimmer all the way up as far as the dash lights.
Old Mar 19, 2008 | 05:18 PM
DPL33's Avatar
yes they are.
Old Mar 19, 2008 | 05:33 PM
Chevy Lover's Avatar
Try pulling up on the park brake pedal and see if the light goes out. The cable may need adjustment.
Did the brake light come on at a time while you were driving?
If you regular brake pedal went down to the floor you may have a leak in the system and the equalizer valve switch has tripped.
See if you can give us more details.
If you do a search you should be able to find a post on how to open the hood when the release cable has broken.
Old Mar 21, 2008 | 04:35 PM
DPL33's Avatar
tried pulling up on the ebrake..no dice. im thinking that once the brakes are fixed, the light will just go off...as you said , it must have tripped that switch letting me know that there is a leak and obvioulsly no pressure is being built up, causing my brake pedal to be pressed all the way to the floor. how easy of a fix is this? or should i just go to a mechanic?
zjones_85
Jul 5, 2013 05:13 PM
rgwoehr
Apr 1, 2012 05:27 PM
chester92
Nov 14, 2011 02:50 AM
jetsmy
Aug 1, 2008 10:10 PM
Aneurysm
13
May 3, 2008 12:27 AM
