Dash screw replacement
Hey y’all I’m trying to find a replacement bolt screws for my 99 blazer dash bezel since the old bezel that came with the truck had the mounting holes broken so I replaced it with a new one and I don’t have screw to fully screw it in. I know it’s a 7mm but I would like the full dimensions.
What dimensions do you want? The hex head size? The length? The diameter?
yes the screws that hold the dash gauge, dash bezel and the radio in. I’m looking at buying replacement screws from Amazon and I want to know what I’m getting matches the factory screw specs
But you likely can find what you need at the local hardware store. That is where I found replacements when I needed extras. You might pick up a few of different sizes and see what works. This also might be faster for you too.
Many nuts and bolts sections have automotive fasteners.
