Daytime running lights
Old Dec 31, 2011 | 04:41 PM
James1965's Avatar
James1965 is on a distinguished road
Default Daytime running lights
I am having a issue with my daytime running lights that started a week ago. if it is bright outside like normal daylight driving both high and low beam lights come on. if and when it gets dark then the automatic lights kick in and high/low beam work normally. I'm just not sure why or what would cause the daytime lights to activate both high and low beams. I was actually pulled over for it so now i'm turning on the headlights everytime i go someplace. any ideas? relays? Hand grenade?
1998 S10 Blazer 4x4 4.3L auto.
Old Dec 31, 2011 | 04:55 PM
warthogdriver's Avatar
it sounds like your ride did the "quad mod" to itself.
its just a guess but there is a relay in the fuse box under the hood that has to do with the drl system.
it sounds like your ahl works...and your bright switch on the column is working...so that would be my guess....just a guess though.
Old Jan 6, 2012 | 11:05 AM
GryphonBlaze's Avatar
GryphonBlaze is on a distinguished road
Depending on what year your blazer is you can turn off the daytime running lights by pressing the dome override button 4 times within 6 seconds.
Old Jan 8, 2012 | 06:59 PM
May One's Avatar
May One is on a distinguished road
What years does that work in? I have a 97 and Im not crazy about the daytime runners so if theres an easy way to get them off Id like to know. Thanks..
Old Jan 8, 2012 | 08:43 PM
98blazin's Avatar
98blazin is on a distinguished road
just do a search on disabling DRL.
you simply have to bend one of the tabs on the DRL relay. search to find wich one, i cant remember i did it a long time ago.
antman94
Mar 7, 2011 08:12 PM
Benedict1337
Dec 10, 2010 08:30 AM
drefda
Oct 5, 2006 01:32 PM
greengoose89
Jun 2, 2006 03:09 PM
RedBlaze
Sep 14, 2005 01:28 PM
