Dead Blazer
Old Feb 27, 2009 | 12:28 PM
missaero's Avatar
missaero is an unknown quantity at this point
Default Dead Blazer
So it seems I'm having terrible luck with this Blazer only two weeks into ownership.
Here's the story. Front left speaker was not working so we checked the head unit and then took off the door panel to check the speaker itself. Turns out it was just a loose connection. In the process of diagnosing and testing, my battery died. We jumped the Blazer from a friend's Jetta and took it for a drive - no problems and it started up again unassisted after the drive.
After getting back to the house, my buddies were working on the faulty mirror on the drivers side. Again the idiots left everything on and the battery died once more. We tried jumping but this time it did not work. We checked out the battery and noticed it was showing age and the connectors were definitely a bit corroded.
I picked up a new battery and new connection bolts. I cleaned the connectors off and hooked everything up. Now the Blazer will not start - even with this new battery! She will turn over but no ignition.
Anyone have any ideas on what might have happened?
Old Feb 27, 2009 | 01:10 PM
danmiranda's Avatar
danmiranda is an unknown quantity at this point
Default RE: Dead Blazer
But a Voltmeter on the battery, how many volts is it putting out?
Old Feb 27, 2009 | 01:34 PM
missaero's Avatar
Actually 12.8
Old Feb 27, 2009 | 02:36 PM
blzR's Avatar
blzR is an unknown quantity at this point
Get a buddies GOOD battery in therebefore anyconclusions of further issues first.Aged,thenCharged batts are suspect.
Old Feb 27, 2009 | 03:17 PM
rriddle3's Avatar
It takes fuel, air, and spark to start. We'll assume it's getting air, so verify spark to the plugs and do the standard fuel pressure test.
Old Feb 28, 2009 | 05:29 PM
missaero's Avatar
So here is the diagnosis: bad ignition control module!
Old Feb 28, 2009 | 06:28 PM
rriddle3's Avatar
Thanks for the update and I hope that solves everything. The ICM generally fails when it gets hot, so normally it won't interfer with cold engine starts. I would not have put it on the list of suspects from what you said was happening, but it sure will intefer with spark (one of the 3 things I mentioned).
Old Feb 28, 2009 | 07:15 PM
missaero's Avatar
She appears to run just fine now. The shop suggested some tune up items but I can take care of that myself for much less $$$
Old Mar 6, 2009 | 07:20 PM
hotredblazer's Avatar
hotredblazer is an unknown quantity at this point
missaero, when your car died do you remember if the dash lights were working? I have a 97 that died on me and I think it might be the ICM
94s10blazin
Aug 10, 2013 01:00 PM
rriddle3
Aug 26, 2007 04:38 PM
frankjc
Mar 3, 2007 11:16 PM
57chevy
Feb 26, 2006 03:18 AM
Jetfixer
Dec 16, 2005 02:32 AM
