Did I kill my 4.3?
Old Jan 30, 2020 | 06:51 PM
  #21
Part 2 of 2.
Old Jan 30, 2020 | 08:08 PM
  #22
Tajohns34's Avatar
Thanks guys. I will start on this tomorrow and throw up some pictures along the way. You are all the best!
Old Jan 30, 2020 | 09:23 PM
  #23
That is a LOT of RTV to find! I'm sure that Les is correct that you'll find more in some of the other choke points of the oiling system as well.
For the LIM gaskets, here is part one of two of the better write-ups I ever found. As of last report, the links are dead.
I've fixed the link as well as created a PDF copy that I host in my google drive so you don't have to upload pdf's in individual threads, you can just point to the Tech Article index. If you find any other useful information that you find yourself attaching frequently, you can always submit a tech article of your own and then just link to that.
Old Jan 30, 2020 | 09:28 PM
  #24
LesMyer's Avatar
And attached is the factory info that I promised.
Oops - was attaching this when Swartllk was posting.
File Type: pdf
Old Feb 2, 2020 | 11:35 AM
  #25
Tajohns34's Avatar
Well, it was supposed to be Sunny and 46 today but now it is snowing and 34. After tomorrow it is supposed to rain all week. So maybe by spring I might get to it. I hate living in PA with no garage, lol.
Old Feb 2, 2020 | 02:18 PM
  #26
Tajohns34's Avatar
Well, the sun came out. I will post pictures when Flickr starts working again.
Old Feb 2, 2020 | 05:41 PM
  #27
Tajohns34's Avatar
So I got the lower intake manifold on. I may have majorly screwed up the torque because the torque wrench i bought doesn't work and I am sure I overtorqued the bolts. Any suggestions?
Thanks.
Old Feb 3, 2020 | 06:48 AM
  #28
Mods's Avatar
Thanks.
Any cracks in the intake manifold?, Snapped bolts or stripped threads? what spec did you use and are you sure you set your torque bar correctly? post a pic of the torque scale on the wrench with it set to the spec you used also, its easy to set it incorrectly if you're unfamiliar with how to do it.
Old Feb 3, 2020 | 08:28 AM
  #29
Tajohns34's Avatar
No, it just doesn't work. It doesn't look like anything is damaged. I am going to exchange it today. I just need to know what I need to do to remedy the fact that I definitely wasn't able to torque them correctly. I was tightening and I knew it should have clicked because it was only set to 27 inch pounds. I even tested it on my lug nuts and it never clicked.
Old Feb 3, 2020 | 09:19 AM
  #30
LesMyer's Avatar
You know that you can post photos on the Blazer Website? I also would like to see a photo of your torque wrench and the scale, or a link to it on sellers web site. Not sure what kind of click you are expecting at 27 inch.lbs. If you're not used to what to feel for, you might only notice the movement of the head when you reach that very low torque - but you can always see that the head starts to rock when you reach to set torque.
As far as the bolts go, loosen them up and start again through the sequence. But you might want to remove them and apply a little more sealer. If they were WAY too tight, then something may be damaged and time will tell.
