Did I kill my 4.3?
Old Feb 6, 2020 | 08:23 PM
  #51
LesMyer's Avatar
Good deal!! Congrats!!
Old Feb 7, 2020 | 02:26 PM
  #52
Tajohns34's Avatar
Thanks.
Old Feb 8, 2020 | 07:16 PM
  #53
Tajohns34's Avatar
Got it all back together but it runs like it is only on 5 cylinders and backfires. I don't think it is timing because I made sure it was back on my mark. I also have a good deal of white smoke but it could just be steam because it is like 30 degrees out and it was idling high. I will double check the spark plug wires tomorrow when it is light out. I marked the wires but I guess the sharpie didn't stay on there, should have used a paint pen. Once I do that I am going to go and buy some cheap oil and change it.
Old Feb 8, 2020 | 08:58 PM
  #54
Mods's Avatar
Did you check the plug electrodes and gaps before putting them in? for a W vin it should be 0.060 and for an X 0.042 iirc.
Old Feb 8, 2020 | 09:16 PM
  #55
rexmburns's Avatar
Super Moderator
Your distributor could be 180 degrees off. It's a common mistake that I've made several times with very similar symptoms.
Old Feb 9, 2020 | 10:16 AM
  #56
Tajohns34's Avatar
Then it probably wouldn't run at all. My marks lined up so I don't know. I will figure it out.
Old Feb 9, 2020 | 10:17 AM
  #57
Tajohns34's Avatar
I never took the plugs out. I am going to double check my firing order.
Old Feb 9, 2020 | 06:02 PM
  #58
Tajohns34's Avatar
I had plugs 2 & 6 reversed. I swapped them and now it runs good. I actually had it running for about 5 minutes to add coolant and then I changed the oil. I used cheap oil from tractor supply and got a cheap Walmart filter. There was a little bit of crap in the oil but nothing major, and no coolant. I drove about 30 miles and I think I will change the oil again tomorrow.
Looks like an engine again.
Old Feb 9, 2020 | 09:09 PM
  #59
rexmburns's Avatar
Super Moderator
Congrats!
Old Feb 9, 2020 | 09:12 PM
  #60
LesMyer's Avatar
Congrats!!!! Sounds like and looks like you did a fine job on your intake gaskets!
