Did I ruin my lower ball joints?
Old Oct 9, 2010 | 06:34 PM
Patrick_Boyle's Avatar
Patrick_Boyle is an unknown quantity at this point
Default Did I ruin my lower ball joints?
I climbed under to grease the chassis for the first time. The lower ball joints took a little grease then the old stuff started squeezing out all around. It seems to me that the rubber seal was/is ruptured. Time for new joints?
Old Oct 9, 2010 | 07:20 PM
robertr728's Avatar
robertr728 is on a distinguished road
It will be fine as long as you keep grease in it. The ball joint will go bad anyways as they usually do on blazers. But they will defiantly last longer if they are kept greased. And quick oil change places hardly ever grease them correctly.
Old Oct 10, 2010 | 12:31 AM
Swain's Avatar
Swain is an unknown quantity at this point
If you go offroading grease them up EVERYTIME you go get the truck dirty, that is very important. If you don't then grease them up once a month and they will likely still last a long time depending on how tight they are right now.
Old Oct 10, 2010 | 10:40 AM
Sounds good to me. The joints seem to still be in good working order. The front end it tight and doesn't make a lot of noise. For future reference, though, when I do end up buying new joints, should I grease them until I see grease coming out, or just give it a pump or two until the boot is firm?
Old Oct 10, 2010 | 05:31 PM
Swain's Avatar
You pump them until the boot starts to expand, then one more pump for good measure.
s10machine
Jul 13, 2014 08:58 PM
Shalom
Sep 29, 2010 07:21 PM
Bullfrog2099
Jul 27, 2010 03:44 PM
Jorgen
Jul 24, 2007 08:40 AM
bigbrett
Sep 19, 2006 10:16 PM
