Died while accelerating, now no start
Old Nov 6, 2015 | 03:44 PM
Camshaft position sensor data enables the PCM to compare variations in camshaft & crankshaft RPM when a cylinder fails to produce power. It does not affect ignition timing, provide data for the tachometer, or change the way the injectors are fired. Cylinder misfire detection and identification is all it does.
Old Nov 6, 2015 | 03:56 PM
No false Bravada's Avatar
No false Bravada is on a distinguished road
The fuel leak down and pressure tests will have to wait a bit. Ihad to get it towed and that wiped out my check this week.
I will be getting the distributor from Skip White performance I saw in this forum anyway. Probably doesn't hurt to have that.
Old Nov 17, 2015 | 10:45 AM
It is the distributor. I was able to turn the rotor by hand.
Old Nov 19, 2015 | 04:10 PM
There's the problem.
Attached Thumbnails Died while accelerating, now no start-img_20151119_163138.jpg   Died while accelerating, now no start-img_20151119_163141.jpg
Old Nov 20, 2015 | 09:47 PM
Toocute350's Avatar
Toocute350 is on a distinguished road
I noticed no one mentioned the ECM.If the ECM is bad you will get a crank but no start also.It`s all about trial and error.Test the easier things first, then slowly move your way up to the harder things last.
Old Nov 20, 2015 | 10:25 PM
That would do it!
Must have missed the pictures of the chewed up distributor drive...
Old Nov 20, 2015 | 10:45 PM
I got a junkyard dist, and this particular yard put a 3 year, unlimited miles warranty on it.
Put it in the Bravada and it started and ran. I didn't get it dead on time, so I got p1345. But at least I'm about 99% done. I'll get it zeroed in tomorrow when it's light out.
Edit: done.
Finally got the timing set, no codes, runs smooth.
Attached Thumbnails Died while accelerating, now no start-img_20151121_170712.jpg
sunchiropractictables
Mar 2, 2024 06:29 PM
Jeremy_in_Texas
Jan 24, 2015 06:58 PM
doccheese
Dec 12, 2014 03:43 PM
zstudna
Oct 15, 2012 07:19 PM
sav25age
24
Mar 12, 2011 09:57 AM
