Diff Gasket Question
Old Jun 21, 2010 | 07:32 AM
Xtreme187's Avatar
Xtreme187 is on a distinguished road
Default Diff Gasket Question
Ok I have a 2001 Blazer Xtreme and need to replace the diff cover gasket. Now I need to know if it is a 7.625 or a 8.625 ring gear. Problem is the tag is not on the axle to tell so how else would I know? Does anyone know what the ring gear sizw is for a 01 xtreme 4.3 liter, rear disc axle etc. Your typical Xtreme. I dont want to order the wrong one ya know??
Thanks,
Jay
Old Jun 21, 2010 | 07:52 AM
jbsnowboarder16's Avatar
jbsnowboarder16 is on a distinguished road
How many bolts does the cover have in it? The 10 Bolt rear end is 7.625 and I believe the 12 bolt and/or the 14 bolt rear is the 8.625, but I'm not sure.
Old Jun 21, 2010 | 03:32 PM
danmiranda's Avatar
danmiranda is an unknown quantity at this point
Usually the 8.5" ring gears are found in the ZR2 Blazers. Its unlikely you have it, unless someone made a transplant on your Xtreme.
Old Jun 21, 2010 | 03:36 PM
89s10blazin's Avatar
89s10blazin is on a distinguished road
hey man, i say check the specs, not sure the codes for that diff but go to a site called comp nine ( check google) if you enter your vin it will tell you everything!!!! axle used, gears, anything!!! down to the colour of your trim
Old Jun 21, 2010 | 04:53 PM
jmaynard's Avatar
jmaynard is on a distinguished road
Unfortunately, compnine told me I have a GU6 3.42 rear axle, but not what size the ring gear is.
Old Jun 21, 2010 | 08:42 PM
abig84's Avatar
You can probably bring your cover in to the parts store. Its gonna be some kinda 10 bolt. The 12 bolt was discontinued back in like 79 and the 14 bolt is only found under fullsize truck§
Old Jun 22, 2010 | 09:45 AM
Xtreme187's Avatar
I wanted to be able to get all the parts before I tore it down but now that I look online at my local parts store the gasket is only 4 bucks each for both so I will just get both and do the job and return the one not used after I get it done but thanks to everyone for helping out!
Now I just need to find someone that has access to a carfax so I can run it on this truck. I have uncovered some bodywork and just curious as to what a carfax report would say about my truck. I went to carfax and it is saying 15 reports on this truck so kinda curious......
Does anyone know of a free place to get one? LOL
limited edition 1
Jan 27, 2023 11:07 AM
mylittletonkatruck
Mar 7, 2012 02:04 PM
J.R. Clay
Mar 17, 2011 08:22 PM
LJ809
Apr 25, 2010 06:02 AM
01gmcjimmy
17
Jan 4, 2008 10:17 PM
