differential help
Old Nov 2, 2012 | 11:01 PM
jrb_fishy's Avatar
jrb_fishy is on a distinguished road
Default differential help
ok so i have the stock diff in my truck with a ratio of 3:43 or so the dealership tells me but i was wondering what can i change the gears to without having to replace everything i want to do a sas swap for the ifs just dont know where to start as of right now or what i need to find to do this
Old Nov 3, 2012 | 12:23 AM
Rottidog's Avatar
Try Search with gears, SAS etc in the Search window.
"replacing everything" is a given for a SAS pretty much though.
Welcome to forum btw.
Old Nov 4, 2012 | 02:43 AM
neo71665's Avatar
First figure out what axles and size tires you want. You decide you only want a dana 30 front then the ford explorer 8.8 keeps the same bolt pattern and comes with 4.11 (and disks on 95+). Also stronger than the factory 10 bolt. You decide you want a dana 44 then that 10 is already undersized and pushing the 8.8. It depends on your plans. When I done mine I swapped d30/8.8 (and now d60/d60) so I left my factory gearing in place. My first set of axles cost me $300 and 2nd set were basically free. Only ran it a year with the d30/8.8 combo and wish I would have saved that money.
Old Nov 5, 2012 | 01:09 PM
Diaita's Avatar
What size tires would you like to put on it?
Drew4711
Oct 6, 2012 12:47 PM
photogtimmyo
Apr 15, 2009 07:18 PM
salvy
Sep 18, 2008 02:23 PM
98BlazerLT4x4
Mar 4, 2008 06:00 PM
tilley101
Jan 7, 2008 07:43 AM
