Which direction does brake pad screech tabs go?
Old Oct 11, 2013 | 05:20 PM
WalkGood's Avatar
WalkGood is on a distinguished road
Default Which direction does brake pad screech tabs go?
Decided to change my rear pads after replacing metal brake line to rear.
Found the old pads had wear sensor facing opposite directions on same axle.
Should the screech tabs go forward (leading edge) or rear (trailing edge) on the pad. All four pads look the same BTW.
Help! It's getting dark!
Old Oct 11, 2013 | 06:03 PM
toyhauler1283's Avatar
toyhauler1283 is on a distinguished road
Picture the wheel rolling front the squealer should be trailing ( after the pad)
Old Oct 11, 2013 | 07:30 PM
WalkGood's Avatar
In this crude sketch , you are saying the black arrow is pointing to where the wear tabs should be positioned right?
Attached Thumbnails Which direction does brake pad screech tabs go?-brakepadweartab.jpg
Old Oct 13, 2013 | 07:15 AM
Correct the black arrow is right
knklhed
Jul 2, 2012 01:24 AM
chris015
Feb 14, 2012 10:20 AM
Mr.T
May 24, 2011 02:21 PM
cueball
Oct 2, 2009 12:31 PM
Acer2428
Jul 13, 2006 11:52 PM
