Distributor Play
Distributor Play
Hey Guys,
I just wanted t re-visit the question about clearances between the cam and distributor gear. So, how much play is too much play and what would the symptoms be from the extra clearance? I feel I may need to remove the cap and re-check the slop with an indicator. I just can't seem to get a smooth running engine.
Later,
Thanks
btw, it's a 96' model 4.3
Later,
Thanks
RexMBurns, Gregg (Graveyard) got the software and adjusted cam retard a while back. Used Dash Command if I remember correctly, as we couldn't get Car Gauge Pro to work on a 1996. Can't remember what the cam retard was before adjustment.
Ahh thank you! Let this be a lesson in keeping all related/relevant information in 1 single thread so that people can know the complete history of what has been done or tried pertaining to the issue at hand After looking up the history just now it appears there are several threads regarding the issues he's been working through. Graveyard in the future please keep related issues to one thread to allow others to better help you by knowing whats been going on from the beginning.
Okay, finally got time to check the play. side to side around the tip of the rotor...about .03 to .035 total. Vertically, around .04 to .045 which actually will increase the side to side but I didn't measure that. I did read my codes and I had a ....p1144 or 42? It was low voltage to the throttle position sensor.
I cleared it, and tried to remember the code but every day is a new day...lol
Later
Later
