Distributor Play
Old Nov 1, 2016 | 06:35 PM
Graveyard's Avatar
Graveyard is on a distinguished road
Default Distributor Play
Hey Guys,
I just wanted t re-visit the question about clearances between the cam and distributor gear. So, how much play is too much play and what would the symptoms be from the extra clearance? I feel I may need to remove the cap and re-check the slop with an indicator. I just can't seem to get a smooth running engine.
Later,
Thanks
btw, it's a 96' model 4.3
Old Nov 1, 2016 | 08:40 PM
LesMyer's Avatar
If you can wait until Friday I will measure my rotor movement with a dial indicator. Cam and distributor both have about 10k miles.
Old Nov 2, 2016 | 09:37 AM
Graveyard's Avatar
Yeah, that'd be great.
Thx
Old Nov 3, 2016 | 07:57 PM
rexmburns's Avatar
Super Moderator
Have you removed/replaced the distributor? What is your cam retard reading at?
Old Nov 5, 2016 | 09:04 AM
Graveyard's Avatar
It seems to settle in around .8 to 1 on average for cam retard. It also is original equipment with a new ac cap and rotor. I have about 113000 on it.
Old Nov 5, 2016 | 11:28 AM
LesMyer's Avatar
The total slop back and forth at my rotor tip measures 0.021" with a dial indicator. This was measured with engine cold. Never heard of anyone posting this measurement before, but I have no reason to expect more play unless distributor gear is worn or end-play in the distributor shaft is excessive and the distributor gear is allowed to ride up on the cam gear. This distributor is a Skip White all-aluminum and the engine a rebuilt GM Goodwrench. Both were new 10K miles ago. Runs like a clock. Hope this helps.
RexMBurns, Gregg (Graveyard) got the software and adjusted cam retard a while back. Used Dash Command if I remember correctly, as we couldn't get Car Gauge Pro to work on a 1996. Can't remember what the cam retard was before adjustment.
Old Nov 5, 2016 | 12:54 PM
rexmburns's Avatar
Super Moderator
Ahh thank you! Let this be a lesson in keeping all related/relevant information in 1 single thread so that people can know the complete history of what has been done or tried pertaining to the issue at hand After looking up the history just now it appears there are several threads regarding the issues he's been working through. Graveyard in the future please keep related issues to one thread to allow others to better help you by knowing whats been going on from the beginning.
Old Nov 5, 2016 | 08:32 PM
Graveyard's Avatar
Sorry Everyone, Your very correct, I should have used the old thread.
Hey Les, thank you for the info. I forgot to bring my indicator home from work. I'll check the slop Monday.
Old Nov 8, 2016 | 01:01 AM
rexmburns's Avatar
Super Moderator
No worries it just helps everyone know whats going on and in turn helps people help you. You are certainly not the first and most certainly won't be the last!
Old Nov 15, 2016 | 06:57 PM
Graveyard's Avatar
Okay, finally got time to check the play. side to side around the tip of the rotor...about .03 to .035 total. Vertically, around .04 to .045 which actually will increase the side to side but I didn't measure that. I did read my codes and I had a ....p1144 or 42? It was low voltage to the throttle position sensor.
I cleared it, and tried to remember the code but every day is a new day...lol
Later
