Distributor Play
Old 02-23-2017 | 08:06 AM
LesMyer's Avatar
LesMyer will become famous soon enough
Originally Posted by Graveyard
Okay, finally got time to check the play. side to side around the tip of the rotor...about .03 to .035 total. Vertically, around .04 to .045 which actually will increase the side to side but I didn't measure that. I did read my codes and I had a ....p1144 or 42? It was low voltage to the throttle position sensor.
I cleared it, and tried to remember the code but every day is a new day...lol
Later
Guess I never responded to your post before now. This really doesn't seem like excessive play in the distributor.
That TPS sensor code seems to be pretty persistent. Still working on that? Maybe it's the problem with both misfire and idle speed. Remember that monitoring TPS angle with scanner is superior way to look at the TPS. What's really important is what the PCM thinks, irrelevant to what the actual voltages might be at the TPS. Might be something as simple as a bad connection.
Old 02-23-2017 | 11:47 AM
Graveyard's Avatar
Graveyard is on a distinguished road
Yes Les, it's been very consistent so far.
kgkern01
06-16-2011 10:24 PM
Franco
04-28-2011 09:51 AM
rasputinlv
01-26-2010 05:18 PM
rasputinlv
01-26-2010 06:06 AM
CDJr
06-06-2009 05:13 PM
Quick Reply: Distributor Play
