Distributor rotor hitting bottom of cap
Old Nov 15, 2009 | 02:53 PM
cc4usa's Avatar
cc4usa is on a distinguished road
it could be that. i still think that since you cant remove the dist. you will need to remove the intake to get the room to inspect the damage. an inspection mirror (mirror on a telescopic shaft) and a small pin point flashlight will help you see the damage better.
trying to fix this yourself is cheaper than a shop (average shop rate $96.50 HR)
dont give up.
Old Nov 15, 2009 | 05:22 PM
If the roll pin has worked its way out, you will not be able to remove the intake as the roll pin is catching in the block above the cam, not on the intake. If this is the case, then your only option would be to cut the distributor off and pull the intake to then get a look at it to determine how best to approach the removal. If you were to separate the stamped steel portion that the rotor sits onto from the main shaft, you should then be able to remove the distributor body. This may give you enough room to get the rest apart.
Another thing to try is rolling the motor over to try and turn the distributor so that the roll pin may point in the other direction. This may give you some more room if the roll pin is currently hitting the cam.
Either way you look at it, it sounds like you are going to be purchasing a new distributor.
Here are some pictures that may help:
Old Nov 15, 2009 | 10:54 PM
cc4usa's Avatar
my bad kyle i forgot what i was looking at as far as how the dist sits in the block. i haven't pulled my motor down that far yet. (2000 ls 4x4) and its been 2 years since i rebuilt my 95 lt
Old Apr 25, 2010 | 05:29 PM
mwillia's Avatar
mwillia is on a distinguished road
Well I got the disty out with a 10 pound slide hammer. It was hung up by the parts that go between the drive gear and the plastic body of the disty. Now to see if I can retrive those parts with a magnet. If not, will those pieces fall all the way to the oil pan?
Old Apr 25, 2010 | 05:39 PM
What parts are you talking about? The washers?
They may fall into the pan, but I would be worried about what they would get into on the way down.
Old Apr 25, 2010 | 09:07 PM
mwillia's Avatar
The flat washer was still there, but the one with the tangs was gone. BTW what is the one with the tangs function?
Old May 13, 2010 | 08:51 PM
mwillia's Avatar
Dropped new dist. in fired right up. Runs strong on hard throttle, but still seems to slightly miss under light throttle. Computer not throwing any codes. What could be causing this?
LannyL81
14
Mar 4, 2013 05:21 PM
dyeguy1212
Apr 4, 2012 09:48 AM
dothedeww
May 13, 2010 04:07 PM
panthersfan101
Engine & Internal
19
Apr 19, 2010 12:08 AM
86Blazer4x4
Jul 16, 2009 02:36 PM
