Distributor timing???
Old May 11, 2012 | 07:11 PM
Project96's Avatar
Project96 is on a distinguished road
Default Distributor timing???
I'm about to replace the lower intake manifold gasket due to a coolant leak. I can't find any info on timing degree BTDC when I reassemble. Should I just mark the intake & dizzy & hope for the best or is there a better way? Thanks.
Old May 11, 2012 | 08:32 PM
pettyfog's Avatar
The intake to Dist is already marked.. with the hold down.
REMOVE ACCESSORY BELT SO YOU DONT ACCIDENTLY TURN ENGINE
Most people turn engine CW till rotor points to t eh '6' point in the dist base lip. Verify Crank timing mark.
As you lift dist STRIGHT UP.. best to note point where Rotor STOPS turning. Where you want to start when you reinstall so the rotor ends at '6'
gtmccormick
Jan 21, 2015 10:10 PM
jimnva
May 3, 2012 05:52 PM
justinh4578
Sep 4, 2011 03:30 PM
dve330
Apr 10, 2011 07:17 PM
Pappa Bear
13
Mar 15, 2011 09:34 PM
