distributor/timing
Old 01-21-2017, 08:04 PM
rexmburns's Avatar
Super Moderator
If you are getting a P1345 code then your distributor is still installed incorrectly. Use this think Installing and Setting a Vortec Distributor Correctly - GM Truck Central to get your distributor installed correctly and then you can go about fine tuning the CMP Retard to get it running correctly.
Old 01-22-2017, 05:24 AM
newguy's Avatar
Along with rex post this video helps also
https://www.youtube.com/watch?v=LOR-9JZUUI0
Old 01-22-2017, 09:27 AM
CWBDDSPC's Avatar
CWBDDSPC is on a distinguished road
Yes, I spent a few more minutes researching the 1345 code. It will set if your CMP retard is off by more than 27 degrees. Each tooth on the distributor is something like 11 or 13 degrees ( I think, would need to double check ). So after you get the distributor in the right spot you'll be able to use your new toys to dial in the CMP retard to +/- 2...
Old 01-22-2017, 09:41 AM
bobs99's Avatar
bobs99 is on a distinguished road
Thanks All! Will Quadrupal Check (more like 29th time) Dizzy position and get back by middle of week. The links are what I went to before but hey I am a weekend warrior who cut my teeth on old Camaros and 340 duel point Duster. Since been Rebuilding VW ,transplanting Transmissions etc... Please dont leave me on this one.
Old 01-22-2017, 12:55 PM
newguy's Avatar
Piston one needs to be top dead center
Old 01-23-2017, 07:05 PM
bobs99's Avatar
ok so that little OBDII bluetooth came in and synced with my phone. Gone over all dizzy settings AGAIN and all is a go. TDC #1 (by Compression Gauge and feel), Both marks aligned correctly on Balancer, and Dizzy on #1. Runs rough and ticks. Scan app says cam retard* 6.7 and cam retard** 17.6 (Dont know what * and ** stand for) But those are the way cam retard is listed. Also says cam position sensor and crank position sensor NOT in correlation. (What does this mean if not Timing Chain Slipped?)
Old 01-23-2017, 07:53 PM
rexmburns's Avatar
Super Moderator
Use the number with the single * and you need to adjust the dizzy so the cam retard reads 0.0 +/-2.
Old 01-23-2017, 09:00 PM
bobs99's Avatar
Will not adjust past 6 and i am now hearing extreme noise in engine. have i destroyed it or will timing gears and chain be all it needs ? Making lots of CLANKING .
Old 01-23-2017, 11:00 PM
rexmburns's Avatar
Super Moderator
You haven't read the links provided to you! You need to modify or replace the distributor hold down bracket to be able to adjust it.
As for the nose it's hard to tell what that may be you said you changed the intake manifold gasket but not what compelled you to change them. So I will ask what happened that you were compelled to change the intake gaskets? More details= more help
Old 01-23-2017, 11:41 PM
papajim's Avatar
papajim is on a distinguished road
Just buy a new distributor and that will fix it. I had to do that for my 02. Amazon has them
Quick Reply: distributor/timing
