distributor/timing
#31
I also do realize that the rotor turns as it drops in and should end up on the triangle not start there and advance past it. Lesmyer you mentioned that both double and single asterick CMP retard in Car Gauge Pro approach zero at the same time. Why are my initial readings 6 something* and 17 something**?
#32
Then you are ready to do the bracket mod and get CMP retard set to zero. However I would not expect a CMP retard of only 6 to cause a severe running problem.
#33
Suspect dizzy causing SOME of the noise as the front cap screw hole broke out as noise became bad. Ordered a new one should be here 31st - 3rd of next week so will continue with plan to check Compression this weekend. Thanks for not putting me off, I will Not be back on till Monday night. Unless I get undesirable Compression readings. OR Dizzy comes early.
#34
Skip White Performance Detail Description
#35
Purchased this on Amazon.Went to link you gave and said Out Of Stock.
Best Seller
New Distributor for Chevy GMC Isuzu Olds 1996-2007 4.3 V6 Vortec Complete Assembly by Parts Player
by Parts Player
$ 40 91
FREE Shipping on eligible orders
Only 20 left in stock - order soon.
4.6 out of 5 stars 43
Automotive Parts & Accessories:See all 5,089 items
Best Seller
by Parts Player
$ 40 91
#36
Best Seller
by Parts Player
$ 40 91
Best Seller
by Parts Player
$ 40 91
#37
Ok. New dizzy here but not in. Ran short on time again this weekend however did get old dizzy hold down slotted enough to get CMP to -.4 . Engine is not changing still Knocking /Tapping . Back to finding time to do compression Test and go from there. I still dont want to believe Timing Chain slipped But WHAT else could it be? Help.
#38
Might be useful if you could post a video of your noise and your misfire.
#40
Once you have it on youtube and have made it public, then link to the video from inside this thread. If you can't figure out how to link the video so it runs inside the forum page, then simply post the url for the Youtube page and we can go there.
Don't get intimidated. It's pretty easy once you have the youtube app and an account. Soon you'll be slinging videos all over the Internet!!
