distributor/timing
Old Jan 24, 2017 | 06:29 PM
  #21
newguy's Avatar
Originally Posted by papajim
Just buy a new distributor and that will fix it. I had to do that for my 02. Amazon has them
you WILL not get the adj. you need with a new dist. you need to( Ihad to) make the adj. hole bigger on the dist. to get the adj. needed. These trucks very rarely jump the timing chain
Old Jan 24, 2017 | 08:57 PM
  #22
LesMyer's Avatar
Originally Posted by bobs99
ok so that little OBDII bluetooth came in and synced with my phone. Gone over all dizzy settings AGAIN and all is a go. TDC #1 (by Compression Gauge and feel), Both marks aligned correctly on Balancer, and Dizzy on #1. Runs rough and ticks. Scan app says cam retard* 6.7 and cam retard** 17.6 (Dont know what * and ** stand for) But those are the way cam retard is listed. Also says cam position sensor and crank position sensor NOT in correlation. (What does this mean if not Timing Chain Slipped?)
It's another way of saying that the distributor is in wrong (cam sensor is inside of the distributor, and distributor is driven off the back of the camshaft). If it still has the P1345 and it runs, the distributor is in a tooth off. If so, put back on TDC#1, pull the distributor and try again. At TDC#1, rotor should point to the #6 cast into the top of the distributor housing where the cap sits. Once you get rid of the P1345, only then set the cam retard to 0 +/- 2 degrees using single asterick CMP Retard in Car Gauge Pro.
As an aside, both double and single asterick CMP retard in Car Gauge Pro approach zero at the same time.
Old Jan 24, 2017 | 10:07 PM
  #23
newguy's Avatar
The rotor needs to be off counterclockwise a bit BEFORE dropping it in. It will turn clockwise as it sets in
Old Jan 24, 2017 | 10:34 PM
  #24
LesMyer's Avatar
I think the OP was trying to drop the distributor in with the rotor pointing to something else than the stamped "6". Note that he claimed "dizzy on #1"
Old Jan 24, 2017 | 11:15 PM
  #25
newguy's Avatar
Ahhh yes, common mistake
Old Jan 25, 2017 | 10:13 AM
  #26
LesMyer's Avatar
Looks like OP has not been back since his last post 2 days ago. Sometimes we just waste our time.
Old Jan 25, 2017 | 06:10 PM
  #27
bobs99's Avatar
bobs99 is on a distinguished road
Just getting back to forum, took some time to do some tractor work. The engine was not making any noise other than sputtering after driving to store and sitting for short period of time which I researched and came to the conclusion that water/coolant was seeping into rear cylinders and took a little time to clear out before it would run normal. Now as for Modifying the hold down bracket I suggested that myself BUT got no clear indication that I should perform that task,even brought my reamer home from work but did not do that. So that was in the links because I totally missed it. My Bad. When I get time possibly this weekend I am planning to remove all the plugs and do a Compression test to make sure It has not damaged any valves or push rods. Will update results unless you think I should just start with Bracket mod and ignore noises.
Old Jan 25, 2017 | 06:29 PM
  #28
bobs99's Avatar
Ok, just got through page 3 sorry for needing to do life I know you are all taking your time to help me straighten this dizzy thing out and I really appreciate it and I understand that you don't and shouldn't have a lot of faith in the man on the other side of the keyboard but let me assure you the dizzy is in the correct tooth. As i said before plug out compression gauge in compression stroke and marks on Harmonic Bal aligned with both marks in links. Rotor pointing at triangle with 6 stamped on it. Pull compression gauge and confirm with screwdriver we are at the top. Know that I totally missed the Bracket mod but as she ran at idle for 5 maybe 10 mins started to get very noisy and have not touched it since. I feel that I do need help with what to do next.Thanks the OP/Bob. By now possibly SOBob.
Old Jan 25, 2017 | 06:34 PM
  #29
bobs99's Avatar
I also do realize that the rotor turns as it drops in and should end up on the triangle not start there and advance past it. Lesmyer you mentioned that both double and single asterick CMP retard in Car Gauge Pro approach zero at the same time. Why are my initial readings 6 something* and 17 something**?
Last edited by bobs99; Jan 25, 2017 at 06:50 PM. Reason: Clarifying Which asterick is which.
Old Jan 25, 2017 | 07:00 PM
  #30
bobs99's Avatar
Rescaned and there are No Codes showing up.
