distributor travel???
Within the last two months I've gone thru two rotors in the distributor cap. both times the tab in the center of the cap have broken off. With my bare hand i can rotate the rotor slightly counter clock wise and has up and down travel of approx 1/8 to 3/16 of an inch. Is it time for a new distributor or a buddy said replace the gasket cause over time the gasket shrinks and allows travel up and down to happen and this is whats causing the rotor to fail.
Any ideas out there?
The inner shaft of the distributor had come free allowing the movement. Once I pulled the old one out I could move the gear up and down almost a 1/4 of an inch. I had never changes a distributor b4 but it went smooth as could be and the truck is running great 185,000 miles here we come
Patrick_Boyle
04-06-2009 08:43 PM
