Does 4WD actuator have a vacuum hose to it?
Old Jan 17, 2011 | 07:15 AM
GunsOfNavarone's Avatar
GunsOfNavarone is on a distinguished road
Default Does 4WD actuator have a vacuum hose to it?
Have a 1998 S10 4wd that indicates that it is working by the push button lights but it is not. Did some checking and discovered the vacuum lines had holes in them.
Also checked the 4wd actuator under the battery tray. It looked ok, but only has a cable connected to it- no vacuum line. There is a male opening on it that looks like it could be for a vacuum line, but I am unsure.
Does anyone know if the 4wd actuator should have a vacuum line connected to it or only a cable?
Old Jan 17, 2011 | 10:13 AM
rob44_90's Avatar
rob44_90 is on a distinguished road
It should have a vacuum line attached to it and a cable running down to the differential.
Old Jan 17, 2011 | 11:19 AM
jbsnowboarder16's Avatar
jbsnowboarder16 is on a distinguished road
The vacuum hose that goes to the actuator comes over the engine and is a pretty large diameter hose. About 3/8 to 9/16in in diameter
Old Jan 17, 2011 | 01:06 PM
Thanks, found it! 4WD now working!
Cassera
22
Oct 12, 2019 09:07 PM
pinbill
Dec 22, 2012 09:53 PM
shotnva777
Nov 9, 2011 06:40 AM
snowmiller
May 10, 2011 04:45 PM
IndianaBlazerGirl
Jan 1, 2011 02:53 PM
