does anyone have a vacuum line diagram for a 2000?
Old Aug 4, 2014 | 11:18 AM
er0ck273's Avatar
er0ck273 is on a distinguished road
Default does anyone have a vacuum line diagram for a 2000?
im not sure if i have a leak, 4wd, hvac and cruise all work fine. but i have a revving problem during startup and was advised to see if any lines are brittle/ leaking, i just had a few replaced mostly on the drivers side of the engine, i know theres some under the battery tray,
also what size lines do i need?
Old Aug 4, 2014 | 03:24 PM
swells87's Avatar
swells87 is on a distinguished road
I would love to see a full vacuum diagram as well anybody know of a good place to find one?
Old Aug 5, 2014 | 10:53 PM
aa21830's Avatar
aa21830 is on a distinguished road
If your HVAC and 4WD work, then it's unlikely you have vacuum leaks. And FWIW, vacuum has nothing to do with cruise control.
If you want to look at the vacuum lines, check out this page and look at the links for transfer case switches and 4x4 troubleshooting. The vacuum diagrams for the 1996 Sonoma and the 2004 Blazer are the same, except the vacuum reservoir is located inside the fender well for the newer vehicles (including your 2000).
Old Aug 7, 2014 | 12:05 PM
lilblazer's Avatar
lilblazer is on a distinguished road
I would also like to see one of those. The guy who I bought my 2000 Blazer off of changed the engine and failed to connect about a half dozen hoses. It'd be nice to know where they all go.
Old May 14, 2016 | 07:07 PM
Jeff Long's Avatar
Jeff Long is on a distinguished road
I have the same problem. Before I bought the Jimmy they had put a new Manifold Gasket installed. Now I have found a vacuum hose without a home. I have a whistling sound coming from underneath the pass/side. The hose has a collar on it
vantoine
Oct 11, 2010 08:41 PM
slickvic863
Jul 16, 2010 08:33 PM
DATEGGY39
Sep 16, 2009 11:58 AM
apoch
Feb 19, 2008 11:04 AM
USMaverick101
Oct 20, 2006 06:46 PM
